same psi I run. I don't see a ply rating on mine but they are 26-8-12 and 26-10-12 which aren't even available that I have foundI was told bias 2 ply on front and 4 ply on rear. I run 12psi front and 14 rear. This weekend when slowing creeping down off a rock and then turning to the left I rolled the front right tire off the bead. Not really impressed with these 2.0s. I had bighorn originals on my rhino for 6 years with same air pressure and never had a problem one. Never broke bead and never plugged. And that was with suspension that wasn't very forgiving.
how wide are your 26's?same psi I run. I don't see a ply rating on mine but they are 26-8-12 and 26-10-12 which aren't even available that I have found
they are ok for a factory tire, I'm gonna run mine 'til they fail, then keep the fronts for a spare
I have a set of og horns in 26" ready to go when I need them
they are 5 lbs heavier per tire than the 2.0's so I'll lighten my od's when I change them
I did 26X9X12 all way around I just bought some. Haven't measured the height of them yet.When I replace I am going with original Bighorns. Maybe 27x9x12 all the way around.
