1 - 8 of 8 Posts
Just installed the led kit and tail lights and brake lights work but no back up lights. Can't even get a closed circuit on relay I used the white blank plug on passenger side front to hook up wire jumper and relay. I have power on 1 wire with key on but no power on any other wire when in reverse I even jumper to other wires at relay to see if lights come on and no luck do I have the right plug
Banned
The Yamaha led tail light with reverse kit comes with everything you need..plug n play mostly. You will need to extend the drivers side black and white wires long enough to reach passenger side. As this kit was designed for rhino originally. It all works perfect other than extending the 2 wires!! Looks awesome!!! Very bright tail/brake lights, the reverse lights are just perfect for backing up at night.
1 - 8 of 8 Posts
