Enjoyed the video.
Well, Can I say I was being conservative since I am running 27" HTR which are higher or taller than the norm and I find them quit adequate in height. I certain have a much better outlook on what to look into should I need another or new machine. Especially if I am screwed in getting my Subaru engine repaired as it should be by default. I'll see this week when I take it in. If Yamaha says NO, then said to say I am done with Yamaha. No trust in my purchasing $$$ for these oem not doing the right thing as its a documented problem. I'd be gone and also not ever recommend these to anyone especially with current issues in the newer models most are unware of.I agree with everything you said except the 27's. Anything new coming out needs at least 29's. 30's minimum on a 1000. Within the next 5 years I see 32's being the smallest tire to get around and 35-37 being the norm around here.
Yes they did. But they did it in such a way that 2019 X2's will see nothing for aftermarket suspension. What out now is as good as it will get. Anything that is not interchangeable with the updated models will become hard to get.I'd hold back on that judgement on the X2/X4 and take the opposite view. They addressed weak points in the shock mounts and improved the rear A-arms to enable larger tires.
I am not looking but the Dropped valve and Fuel pump issues are crucial and should not be ignored. Unless you're getting both addressed out of the gate before taking delivery of said machine.I'd hold back on that judgement on the X2/X4 and take the opposite view. They addressed weak points in the shock mounts and improved the rear A-arms to enable larger tires.
Agreed, I watched two of the videos and I kept waiting for the trees!I wouldn't classify those as tight trails.
They are actually roads with underbrush and limbs grown in on the sides.
The KRX will not physically fit on some of our trails.
66" is all that will go between the trees and we have sharp turns that even the shortest sxs's have to back up and do a double take to get around most of the time.
Very true! I knew what you meant.They are not he tightest stuff for sure, but I think they show what most the wv outlaw trails and pa trails look like. The much tighter stuff is usually private land. Most of the trails in PA and WV are railbeds, old haul roads, old county roads or gaslines.
We had one for about 10 years before the new road went in. We stopped maintaining this drive about 6-8 years ago. Its was are only access from about 2000 until then.I know guys that have tighter and rougher driveways.....lol. J/K
Only riding I have done in KY is Black mountain in the Zuk.I wouldn't classify those as tight trails.
Precisely, we've learned that from Snowmobiling for decades. The deep fluffy powered white snow can easily hide disasterous obstacles and some enough the gut the engine right out if you line up between the skis as the first instance I say too many decades ago to remember other than it was a Red Rupp Sled. Snow or grass, brush even you have go slow unless you'd been on the exact path know/remember 100%.Ok, I watched a few more and most aren't all that tight. I only watched the mudhole one and skipped around a few others before posting that. Those are the type trails that in my experience damage the most stuff. Theres always a log, rock or stump just in the weeds waiting to rip something off.
