1 - 20 of 23 Posts
Hello Fellow Wolverine RMAX Owners,
I recently purchased the RMAX2 3 weeks ago, after pulling out of the garage my wife hands me the following wiring harness pigtail connector. I searched all over the factory wiring harness and cannot find the proper home?! Before off-roading I’d like to discover it’s proper location; have any of you encountered and/or know where this guy belongs?
On a side note: I recently installed the Yamaha a-arm guards, as well as Yamaha brush guard; however, I do not remember bumping into any harness connectors during installation.
94075
94076
94077
Thanks,
Jason
I don't have my R-Max at home right now (its been at the dealership the last 6 weeks trying to get the power steering fixed), but I think I remember a connector like that behind the fire wall right behind the LCD screen. All connectors should have a cap on them so if you see any open connectors that it fits, that's probably where it is from. Or it was just something dropped in the machine on accident during production.
Discussion Starter #3
Hate to hear your dealing with power steering issues for 6 weeks; here’s to hoping it get sorted out ASAP! I’ll be sure to pull the firewall tomorrow and double check the connectors behind the LCD screen! I’m hoping to find it sooner than later, before off-roading and potentially encountering corrosion issues from moisture.
Thanks
2021 RMAX4 1000
It definitely looks familiar if I come across it I'll let you know.
Discussion Starter #5
Thanks everyone! If I can find the location I will certainly snap a photo and reply to the thread. I plan to look the machine over no later than tomorrow. Thanks
It is more than just a cap it is a jumper. I wouldn't go blindly plugging it anywhere it fits unless you know it really belongs there.
All unused capped circuits I have seen do not have a jumper wire on them. This one appears to be jumpered for a specific reason. It does look kind of familiar, or maybe it was some sort of test plug during assembly? I cant imagine it just falling out, they fit pretty snug when plugged in.
Reactions: MassiveOverkill
Discussion Starter #8
I agree, I was taken aback when my wife found the connector laying in the garage where the Wolverine was parked. It would take serious force to remove the cap if it were fully seated; I can’t foresee how installing the brush plate & a-arms guards would disconnect it?! Everything seems functional on the unit; however, the jumper wire has me somewhat concerned... I’m going to remove the firewall tonight and try to determine where it belongs?! Thanks Everyone!
Hopefully they just dropped it in there during assembly and they couldn't find it until i fell out just for you, LOL
Reactions: Hahny
FWIW. I’ve been behind the firewall on mine at least 4 times now. I don’t remember seeing any three prong connectors. Let alone one with a jumper.
There is a three prong connector under the hood, up front, but it doesn’t have a jumper connected.
Does yours/ do these have valet/restrictor switch ?
2021 RMAX4 1000
Without looking into it though, I don't think the standard model RMAX2 comes with turtle mode key under the hood but that aside I have disconnected my switch many times already to remove my firewall to wire accessories and the connector is definitely different than that one.
Is there anything at all not working as it should? All lights, winch, etc?
Discussion Starter #14
Everything seems functional at the moment, I’m going to check the 4WD & tail lights tonight. So far the winch, head lights (low & high), dash and etc still function flawlessly. Thanks guys!
Discussion Starter #15
Correct, the base models do not come equipped with the turtle mode switch.
Maybe someone who has installed a D mode switch can advise if one of the connections had a jumper plug on it for Trail mode only on a base model?
Discussion Starter #17
I was just thinking the same thing. I did install the Rocker Style D Mode switch a couple weeks ago and it been working perfectly. The jumper would make total sense to keep it locked in trail mode.
2021 RMAX4 1000
The D-mode switch plugs are just capped with no jumpers when not installed. The plugs are different as well.
94094
94095
Discussion Starter #19
I checked all lighting and installed accessories, everything is functionally sound?! I’m going to pull the firewall tomorrow after work and further inspect all harnesses. I did notice a small amount of black factory paint on the connector... if push comes to shove I’m going to contact my dealer and see what they say. Thanks Everyone
The d-mode has a 4 pin and a 2. The firewall is off mine right now and I'm not seeing that connector. As mentioned there's a 3pin under the hood front drivers side. No jumper though.
1 - 20 of 23 Posts
