I serviced the clutches this weekend at 1200 miles and 100 hours. Yeah, I tend to crawl around at slower speeds, and need to find time to ride more...
Found a nickle size rust-like spot inside the primary collar and on the same point on the shaft at the fixed face. And found the secondary fixed sheave was mottled. Any ideas what could be the cause? There has been no moisture in the case on my part and I've had no issues while riding. I may have sniffed up belt rubber once or twice after stopping which I assumed was normal even for an ultramatic. All else looked relatively normal to me. The spring cup had some small anomolies in the rubber at the base where the spring seats in the lip. The belt measured 38mm. I cleaned the sheaves with brake cleaner, replaced the spring cup with a new one, installed slippery washers and Tinkseal. Also went with 24 gram rollers and UTVE sliders in the primary.
The Zetek cleaning swabs were perfect for cleaning the grease out and applying Tinseal: https://smile.amazon.com/gp/product/B01DX7N2B0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1#
