I'm the only one who brought up drivers door alignment. I'm a 32 yr helicopter guy and I notice stuff.
It works perfect btw, but doesn't look perfect.
Here's a pic of a 90k Tesla I took the other day.
That door is not lined up correctly either. Though I'm sure it works fine.
I'm a slow typer. I was working on that way before your post. 😁
There is something more with the clutch weight wear. It's pretty rare and inconsistent. Kawi is replacing any with issues. There is no tank issue, shitty gauge, shitty vent, same as Yamaha. I did forget the driveshaft, edited OP. The door bushing is not a problem with bushings, but hinge tolerance. Someone made a shiny brass bushing and now everyone needs it. If you have that issue a washer will fix it or if you want to get real fancy a thicker bronze bushing for a buck at the hardware store. Don't forget there is thread on here bitching about Rmax door alignment also. Heat and noise are not an issue. I'm not real sure were you keep getting that one, I haven't seen it mentioned other than by people that put front and rear windows then wonder why it's hot. It is cooler and quieter than the YXZ(first gen), Gen 1 Wolverine and Can am X3. Those are the only machines I have enough summer ride time in to state that as fact.
