1 - 5 of 5 Posts
Just a heads up for anyone interested -
I went through and checked the CVT breather hoses/pipes and air intake hose clamps for tightness, and half were so loose I could turn the screw head with my finger.
The breather pipe coming off the bottom of the CVT case pulled right off.
Another hose was snug but not completely slid onto the hard pipe.
I went through and retightened all clamps/connectors. Not a bad idea to check yours if you haven't already.
I found the exact thing on those cvt clamps when I did my last maintenance.
Banned
doh... didn't remember this was two parts, sorry
we waited for the adhesive to dry
I strongly advise reinforcing this tube. Mine was crushed and the clamp was improperly tightened.
You will suck dirt and water into this tube if it isn't connected properly.
here's what I did to fix mine
also check your rear diff vent tube
some are loose and fall down
1 - 5 of 5 Posts
