My opinion would be an emphatic no on the (4) bolts that attach the cage that supports the end of the primary shaft. These 4 bolts are soft and are torqued to a very low torque. They can tend to corrode some in place, making them harder to get out, when they haven't been removed in a fairly long time. By adding any LocTite to them is going to add more resistance to get them out and may cause you to break off one of these bolts that are not hardened. I have not ever heard of anyone having a primary cage bolt come loose. I believe Jomo had 1 break off in the hole a couple of years ago and it sounded like a pretty big ordeal to get it out.Would it be a good idea or a bad idea to put Loc Tite on both primary and secondary clutch nuts as well as bearing support housing bolts??
Would tinkseal outperform nickel anti-sieze on an application like the exhaust tip bolts?Loctite is not necessary on the main sheave nuts when torqued. The only time they come loose is if you do not have the spacer (washer) centered. I use TinkSeal on threads like spark plugs, exhaust bolts and oil drain plugs. .
Great comment and is what I’ve also been told by bolt manufacturers. Bolt torque values are determined by the stretch of the material and spec’d either dry or using a specific lubricant. A lubricated bolt will stretch more than a dry bolt given the same torque setting on the wrench.Let me stir the pot lol............ I could be a little wrong here but do not think so..... If you lube threads, you are changing the sliding friction of the threads and the resulting clamping pressures and maybe the yield of the fasteners as well as the base thread material. So torque specs get adjusted. I know in TTY bolts (maybe not all) that the threads are required to be lubed and premier companies like ARP have a house lubricant they require to be used on many of their fasteners. Method beadlock wheels IIRC have two torque figures depending on lube or no lube. And Loctite till cured is lubed, right? Now I will need to do a little research and engineer types jump on on this........
Zero issues on every auto I've ever owned, and every off-road machine until the KRX. I lost three wheel studs on the KRX, the threads just wore out/pulled off. One thing that is different on that machine is the wheels are lug centric, not hub centric. Anyway I changed all the KRX wheel studs and quite using anti-seize.That's not good. I've anti seized my lug nuts already.
If the studs wore out, and you probably checked this but for others not as knowledgeable, as the wheels get loose, even ever so slightly, and start to move, even ever so slightly, then they begin to grind on the studs and the softer aluminum wheel will loose material in the lug seat and start to wear an egg shape. So check the wheel lug nut seats for true cone and concentric-ness.Zero issues on every auto I've ever owned, and every off-road machine until the KRX. I lost three wheel studs on the KRX, the threads just wore out/pulled off. One thing that is different on that machine is the wheels are lug centric, not hub centric. Anyway I changed all the KRX wheel studs and quite using anti-seize.
I use TinkSeal instead of anti-seize because one of the nano particles will withstand over 3000°F. I have had mixed results with antiseize paste, but never had a stuck nut after TinkSeal application.Would tinkseal outperform nickel anti-sieze on an application like the exhaust tip bolts?
