. Perfect ,thank you!! Now would you say that's "7200" is about 1000 - 500 rpms under "red line danger area" or is that its actuall red line for this engine"With the powercommander and raised Rev limit/sheave mine hit 61 at 7200rpm. So I'm guessing 7100 is probably the regular limit. Think I was hitting about 42 in low but with 28" tires that would be 46ish by GPS
. It's everything I'd hope it would be. Very fun and so comfortable!Oh ok. Well I think once you choose to open her up you will see something near 54. Dealer just playing it safe which is good. It sure is a fun machine though isn't it ?
Your engine should go well into the 8000 rpm range, possibly 9k before it disintegrates. 8500 is probably true red line. Your rev limiter and lack of power will keep you from reaching that number.. Perfect ,thank you!! Now would you say that's "7200" is about 1000 - 500 rpms under "red line danger area" or is that its actuall red line for this engine"
