Just bought a r spec today and was wondering what led light bar size and the brackets yall are running. Any info would be much appreciated. Thanks.
now that's a good idea, how did you determine the high beam only hot wire?Here is the setup I ended up going with. 44" across too wired with relay to come on with high beams.
ok thanks! someone, maybe you, posted on here that it's the yellow lead from the light switch....I grounded the negative side of my test light and used to positive side to determine the high beam wire. If it's the right wire the rest light will go on and off with the headlights going from low to high.
Brown is Key ON. Yellow is High Beams. You pick lol.Alright guys, is it brown or yellow
before I do this thing...
