1 - 15 of 15 Posts
I have a 2019 x2 and want to install a light bar on roof but I'm worried about them being damaged. The trails we ride have a lot of over hanging branches..or lights on front. Anybody have any tips or videos of how the installed them.
You need long ROPS brackets to mount to the bars overhead or it will bounce. Plus it might bust roof. If light bar is long enough you can mount to side pillars.
I would mount a small bar to the bumper. Search forum, I have a bumper mount post.
I have mine mounted to the roof with no issues caused by low hanging branches over the past three years of riding. (Yamaha 15")
93714
Right, but where and how are you mounted? To the cross brace on the ROPS?
Yes I am.
Reactions: SKELLEY521
Banned
We go below the roof line, bar to bar or on the hood. We've still broke them in both places but it wouldn't make it very long on the top. One broke the mount and the other pulled the threads out, both repairable. There are a lot of times we push under stuff so hard the suspension compresses.
Not the best pick I just put it on.
I had limbs, etc. beat the crap out of this one and never an issue.
93788
93789
Reactions: Chebbyfan
No it didn't, just roof mount. It was originally designed for the YXZ 1000.
Mounted on the roof with big washers on the underside.
93799
94084
Like movin2stereo mounted through roof with large washers. All stainless hardware. Went with single row low profile light bar to present less of a target for low hanging branches.
View attachment 93788 View attachment 93789
Any ideas on where to get mounts like that?
I have a 52" Harbor Freight lightbar I would like to mount similiar to this. I have it mounted now but bounces way more than I like. Mine is actually mounted above the roof right at the front but could change that easy enough.
Took me a bit to find where I got them, really great mounts, solid, zero movement.
94109
The clamp is available all over ebay. They are called a Bull Bar Clamp and priced anywhere from ~$12 - ~$16 for a pair or ~$21 for 4 of them. 2X 1.5"/1.75"/2" Bull Bar Roll Cage Mount Bracket Tube Clamps LED Light Holder | eBay
Pay close attention to the details when ordering to get the correct size for where you are mounting them. Also there use to be one that looks identical but with a shorter arm, the shorter arm won't always work like you may be wanting to use it. After you look at several you can pretty easily tell the shorter arm from the longer arm version. The longer arm is the most common.
Reactions: TN_Max
Thanks for the info
1 - 15 of 15 Posts
