Gen 6 LED Headlights H4 | eBay Thoughts??
My thoughts are......You should give them a try and come back with a product review.........you know.....for the good of the Wolvy community.Gen 6 LED Headlights H4 | eBay Thoughts??
HAHA! I'm taking donations lol. They are actually the first I have found that said they fit the Wolverine. I really wanted to see if anyone had them already and what they thought.My thoughts are......You should give them a try and come back with a product review.........you know.....for the good of the Wolvy community.
The "H4" should be controlled through a specification, probably through SAE (Society of Automotive Engineers), an international standards originator/enforcer. The specs will control the socket interface and outline of the "bulb". It will also document the locations of the light sources such that the reflector and lens will properly project the beam out in front of the machine. When you get into LED chips as the light source(es) there is always the difficulty of the patches of light pointing out to the side do not emit all the way around the bulb as it does with a filament or HID bulb. So you are taking it on faith that the designer and manufacturer of the particular H4 LED that you are buying did a good job of optimizing the light pattern that is going to come out the front. There is a risk on the buyers part, even though the seller states that it works with a particular machine. In theory, the standards that should have been met should make the H4 format work in any machine designed to run H4 bulbs. I would expect that any mechanical fit problems would center around any rubber boots and the like fitting around the heat sink at the back of the bulb.Amazon says they don't fit the wolverine.
Just so that I am clear on this, do they say that those particular H4's do not work on a Wolverine? Or do they simply not list the Wolverine as part of a list of where the H4 does indeed work?Amazon says they don't fit the wolverine.
The problem with upgrading H4 halogens is heat. I don't know how much heat those plastic housings can handle. Yes you can put PIAA H4 bulbs in and they will be slightly brighter. But most people purchase HID kits that just pop in for better light while retaining the lower temperature and power requirements. I ended up replacing my whole light fixture with a self contained led fixture and lamp. Although, my HID's were okay.Anyone know of any direct fit replacement bulbs? I already ordered an 18" LED bar for the bumper....just want to upgrade the damn dull ass headlights now.
I suppose I'll look into HID's and your idea as well.The problem with upgrading H4 halogens is heat. I don't know how much heat those plastic housings can handle. Yes you can put PIAA H4 bulbs in and they will be slightly brighter. But most people purchase HID kits that just pop in for better light while retaining the lower temperature and power requirements. I ended up replacing my whole light fixture with a self contained led fixture and lamp. Although, my HID's were okay.
