1 - 11 of 11 Posts
So is it possible to add a switch (and some wiring etc) and have a front and/or rear adjustment? Vs just an all four corners adjustment?
And how different are the RMAX2 vs RMAX4 rear shocks?
Thanks!
I don't think so. Even the aftermarket IQS uses some kind of control module.
RMAX4 front main spring has 105 lbs higher rate than the RMAX2
RMAX4 rear main spring has 55 lbs higher rate than the RMAX2
Yes pricey! The main reason I want an LE.
My hunch is the aftermarket is working on an independent front/rear version but I dont know details.
Maybe just as we suspect, a switch and upgraded ecu might be all we'd need so I'd imagine it'll be much cheaper than buying the full kit if its a viable option.
Thanks!
I just got an answer to your question. Approximatelt half way through this video Justin answers my question.
1 - 11 of 11 Posts
