Hello everyone, I own an RMAX. I would like to know if you have a knocking noise while driving, in the front section. The noise is especially present at mid-speed, between 55 km / h and 80 km / h. It makes a knocking noise, as if two pieces are banging together, it makes “CLOC CLOC”. No need to drive on a rough road, the noise is also present on an asphalt road. Whether I'm in 2WD or 4WD, it doesn't make a difference. It's not the winch tie either, because I put a rubber tip. These aren't the heat sheids either, because there aren't any in the front section, only in the back section. The noise has been present since my first test drive. For example, I can drive at a constant speed, 60 km / h, and the noise is continuous. Did anyone experience this same problem and did you find a way to fix it? Also, often, while driving at a constant speed, around 70 km / h, I feel a rumble in the transmission.
Thank You
Alex
