1 - 4 of 4 Posts
Are you not concerned being that close to the cover when it comes to belt wear? As the belt wears it gets narrower and falls in primary and raises in secondary ... not much room for this
Vendor
No sir Im not, there is more room than it looks, about 1/8" and also I don't see the belt moving up with wear, if your belt is that worn you need a new one and you can always take the .5 mm shim out we are going to be using in the primary.
I put a narrower belt on it to see also, we used to run the Viking with same clutch with a 660 belt which is narrower and that was never a issue there.
Todd
1 - 4 of 4 Posts
