First time working with wheel spacers. I have a 2020 Wolverine X4. I just installed new 28x10x14 ITP ultracross r spec tires on black rhino rims. The front tires are close to rubbing the tie rod end. So I am looking to get wheel spacers for the front and possible the rear to square up the machine. What size wheel spacers should I get for the Front and the rear to square up the machine? Ive read some reviews on wheel spacers where it should be 2 inch on the front and 1 inch in the rear.
Also do I need to match the thread size that my machine has to the wheel spacers?
Thanks in advance for the help!
This is incorrect information because being that it’s not a square set up from factory, the fact is that it is wider on the front than the rear. When you use wheels front and rear that are the same offset as you are doing then to square it up you only need spacers on the rear. 1” spacers will square it up or pretty close. Some use 1.5 to make it a scoosh wider on the rear.
What is the offset of the wheels, and the width? A 5+2 offset and a 7” wide wheel is the norm. If your having clearance issues up front then maybe they are 6+1? Set in to far for a 7” wide wheel where as the stock wheels are more inset than the rear to make it square but are also a narrower wheel than 7” and the stock rear wheel is wider than the usual 7” wide aftermarket wheel.
2” in front and 1” in the rear will have it looking pretty ridiculous.
You do have to take into consideration if a rub is happening on jack stands as that replicates the real world of the travel going up and down. Also does it rub turning to full lock one direction and the other.
Depending on the offset and wheel width, you may need a 1” up front and a 2” in the rear.
That pic looks way closer than the norm!
