I installed a factory yamaha heater system in my Rmax X2 early this winter, works great when it's cold.
Today was the first time I had it out for a 65 mile run and temp was 74 degrees. Well now I can feel a lot of heat coming up under drivers seat, it did get quite warm in the cab, heater fan completly turned off and vents closed.
So now my next project is to install a water shut off valve in the 5/8' heater hose coming from the engine to the heater, that should help alot in the summer months.
Just a heads up, if you are going to install a heater I would also install a heater control valve.
Thanks
kenner
Thanks
kenner
