1 - 5 of 5 Posts
got home from dealer today,and noticed headlights are loose,there is a small Philips scew and a large Philips screw,the small screw is loose and can't seem to tighten it,has anybody had this issue?
If you are tightening the small screw at the bottom rear of the headlight, that is your up/down headlight adjustment. There are 3 bigger phillips head screws holding each headlight in. One on the side near the radiator which is hard to get to without a stubby phillips. One on the opposite that is removed/tightened through a hole in the black plastic nose trim that the headlight mounts in. The last one is underneath and screws vertically from the bottom. It actually holds the adjuster/small screw into the channel it is mounted in. If any of the larger ones will not tighten, you stripped out.
I see what yu are saying, I think I got the adjuster screw to hold ,was wondering why my lights were shining on the tops of the trees on high beam
1 - 5 of 5 Posts
