just measure the distance between the top posts to know what length you need,i had to shorten mine from my rangerI just looked up the quick draw gun rack never heard of it till i read this thread. i can't see where they make it for the wolverine. can someone tell me which one to get?
Where are you grouse hunting this year? We just got our new pup back from boot camp and will be up near Finland most of the fall. I have the same dilemma. I need to have a crate in back plus the guns. I was thinking maybe having the crate with the boots mounted on top of the crate. Each rider can then have access to their shotgun....a thought in process?
This is the factory gun setup. It requires the accessory bar ($150),gun boot mount ($200), and the gun boot itself ($60-$107 each). The Deluxe gun boot has a soft kolpin case that goes inside of the kolpin hard gun case. The only part I don't like about it, is the height. I was hoping that it would be higher up, so I could fit a larger dog kennel/crate underneath the mount. I'm going to use my wolverine for grouse hunting the woods and deer hunting also. The mount system is rock solid and I like that you can remove the rear half of the boot while the front part stays locked into the mount.
