Couldn't wait any longer, just had to order it! Looks like a well built lift and easy to install.
I'm fighting it to..lolJust ordered it!!! debated on waiting for other options to arrive on the market... but my OCD kicked in lol
I'll have to measure it..I need to adjust my springs, they are stl at the preset from the dealer.Epic, what is your ride height front and rear? I'm at 12 1/4 front and 12 1/2 rear.
Gotcha, I'll try to get the measurements this weekendBefore you adjust.. I want to know what the front and rear rake is. Mine is at a 1/4inch rake from front to rear. Just seeing if it should be more or less.
Measured today with the spring set from the dealer with the 28's 11.75 inches in from and 12in in the rear.Before you adjust.. I want to know what the front and rear rake is. Mine is at a 1/4inch rake from front to rear. Just seeing if it should be more or less.
Just got mine installed & with my 28" mud lite xl's the think looks sick !!!!! On my rocker back near the flare out on the side I got 18" & near the front 16.5" I know it's the side & its 2" higher then the center but it looks good. Will test it tomorrow & hopfully post pics? Overall was a easy/ quick installation. Everything fit well the front blocks were tight had to tap em in with a rubber mallet, the rear fell right in place. Took the shocks completely off made it easier to drill the 10mm holes.Looks nice! I think that thing would look sweet with 28's
