1 - 7 of 7 Posts
Anyone else notice the front end/wheels/breaks squeak when you ride slow and especially when you turn? If so what is it? I was hoping that this is just a thing yamahas do. Other than this i love the wolverine. Any input appreciated. I've tried spraying up in the wheels real good to get any dirt out. I dont really mud ride much. Sounds like its coming from the wheels behind the rim or maybe the breaks, i dunno..
My left front does this too. Had it checked and could find nothing. My guess is the disc is slightly warped or has a high spot that gets touched ...
Rust on the disc will cause a squeak. Get some speed up and hit the brakes hard.
Discussion Starter #4
thanks ill try that brakes hardly ever get used on mine cause i just use the engine brake never ride at high speeds to much, but will definitely try that.
Definitely sounds like the brakes. Mine get drowned in mud a lot and just getting little bits of stones or something in there can cause an intermittent squeak. Mine squeak now and then too, no big deal.
Mine does it, and if you were ever around Yamaha Rhino's-Grizzlys you will know that almost everyone of them squeaked a bit too.
Discussion Starter #7
i can accept the squeak my rancher was a squeaking son of a gun just was making sure it wasn't a bigger problem but squeaking brakes ever now and then aint no biggie, thanks!
1 - 7 of 7 Posts
