1 - 10 of 10 Posts
Does any one make a 2" front receiver hitch for the Wolverine so you can a put a multi mount winch
on the front as well as the back?
Sean
I like that idea. Although I have already bought the front fixed unit - I saw a set up using a 2" receiver on an old Rhino and thought that was brilliant.
my Kubota 900 had the front hitch and was handy as their blade system hooked into it and was also good for spotting trailers,i still have the winch mounted on 2'' tubing that I could use on the front or back.
Any new info on this subject?
my son had a receiver made up for his teryx and they bolted it to the fixed winch position,we are going to hook up the wiring tonight.
Banned
I would make sure the receiver/winch mount is bolted to the frame somewhere as well as bumper plate and not just the factory bumper. If so I would be careful not to put it under to much load.
I made this with scrap I had laying around the garage and I found the receiver laying on the road. Cut it to size and did a little welding and It attaches to the frame in the back with a piece of bar stock.
Sent from my SM-T350 using Tapatalk
1 - 10 of 10 Posts
