41 - 60 of 70 Posts
Another thought. Isn't the frame powder coated from the factory? So they are grinding off powder coat and hitting with a little paint when finished? I'm sorry but this is not an acceptable repair for brand new machine.
2021 Rmax4 SE
I just had a look at mine and it looks like the welds are there on my machine. Based on the location from my recall notice anyway.I'll bring it by the dealer so it can be checked off and incase there is something more to the recall.
Reactions: wolvymanx4
Discussion Starter · #43 ·
Interesting, does your notification have a different picture diagram than what's been posted? I guess they could have eliminated confusion by taking an actual picture and outlining the weld or even stated 'vertical' or 'horizontal' welds.
2021 Rmax4 SE
No no different diagram. Just comparing my machine to the picture on the one I posted.
When I posted the recall originally I didn't go out and look at my sxs and after going out and looking last night and reading the recall a couple times I'm thinking it's just the inside horizontal welds. Like I said earlier I'll still bring it in incase I'm missing something. But with the arrows pointing to the bottom inside I'm only assuming these were the welds they were concerned with. There doesn't look like there is anything else there to weld.
Reactions: MassiveOverkill
I agree and mentioned the removing of the paint a few posts back. I am in the Rust belt and drive in the winter when I can. I wouldn't want to see rust on the frame at all. This is a real mess on their part as said for a machine of this cost. I'd have the machine inspected only and see what the dealer says. Refuse the repair unless you're really happy about what is going to happen in that regard.
I think this is the weld in diagram.
Reactions: Sparky87
2021 RMAX4 1000
Ok now Im confused. I dont think that there is any spot for horizontal welds. Only vertical. Here's pics of mine again.
90740
90741
Back of the bracket, bottom edge of frame. The plate to the frame, not the bracket to the plate.
If I'm seeing what I think I see in your second pic it looks like it's there on your machine.
Discussion Starter · #49 ·
I don't think the horizontal weld is weld in question. Look at the big bowtie welds on the larger bracket that go on each side of the frame. I think it's the vertical welds that risk being compromised.
Initially, just glancing at the picture, the upper welds could be in question, but the red arrows are only pointing the the side welds. I've updated the OP based on the document you provided, thanks.
I don't know for sure until we see a picture of missing welds, but the diagram you posted seem to call out the bottom inside pretty clearly.
2021 RMAX4 1000
I see now. Gonna have to double check those ones. I wasn't even thinking the plate to frame welds they look so stout on the side of the frame. I'll have to check them for the inside ones though.
2021 RMAX4 1000
Just a follow up. I checked the welds on the inside of the shock mount plates and my RMAX4 has them. Everything seems to have welds everywhere so I think I'm in the clear. If I still receive a letter Ill take it in to be checked off but until then Ill keep motoing.
my machine has been in the shop now for almost 3 weeks. The owner of the dealership called me yesterday to tell me they are still waiting for the drawings from Yamaha. Has anyone heard how Yamaha is going to fix this?
2021 RMAX4 1000 LE
If these frames were dipped for rust protection , welding will burn off internal coating. They simply can not ever be fixed "properly" in my opinion. This is one big f-up by YAMAHA. Hopefully not many are effected , but if mine was I would be talking about replacement. I know that is unlikely, but certainly optimal.
2021 Yamaha Wolverine RMAX4 LE
From my dealer...
92352
And the letter that Yamaha started sending out..
92353
2021 RMAX4 XTR
And the letter that Yamaha started sending out.. View attachment 92353
Yes that's the letter I received today I talked about in the other thread, When mine goes in for first service I'll have them check the welds, and I want to seem them myself so I know they ways checked although I'll check them myself next time I pull it into the garage !
Not sure. Dealer printed that one off for me and said that was the weld that had to be inspected. I’ll ask and see if I can get the rest of the bulletin.
That would be awesome thank you! Better safe than sorry. I will get mine in eventually but am an hour from my dealer and would like to see it with my own eyes.
41 - 60 of 70 Posts
