That depends. Do you like to rock out while pulling rzrs from the hole? If so, then maybe. Otherwise, as long as you leave the engine running while using the winch, you should be fine. Now, if you are running a competition stereo with a few thousand watt amp etc., then maybe consider the second battery.
