Engine stall
1K views 13 replies 7 participants last post by  Olaf455
#1 ·
Hey all I have a 22 xtr 2 seat.just turned 10.000 miles.now machine continues to stall when I stop.not all the time.but more and more frequent. Any thoughts.or anyone had this problem. Thankyou in advance.
#2 ·
First thing I would check would be both air filters on the intake, After a one week very dusty dirty trip Mine got pretty bad and it didn't stall but it seemed like it wanted to.
#3 ·
I don’t know what you mean when you say stalls when you stop. If you are running a little hard, then hit the brakes, and as you come to a stop it immediately stalls, check the one way bearing. If it stalls after you’re stopped, and just sitting at idle, it’s something else.
#4 ·
If you haven’t done any valve adjustments in those miles, my bet would be on tight exhaust valves.
Reactions: OR Traveling Rmax
#11 ·
Your vague description leaves me feeling like it is a vacuum leak. I believe OR comment #3 is on focus and you have not answered it. I would check using some carb cleaner and spray around the intake boot while someone helped feathering the throttle and checking TPS & PCV systems before I started tearing apart the motor....
