Is it between seats or under bed. I can't tell from pics. I'm torn between yxz,Viking and the wolverine. So I'm researching all three trying to get as much info as possible. I know the Viking is easy to access the motor
Where exactly is oil filter & oil fill, & how do you get to them? Thanks much!But for regular maintenance it's a snap. The oil fill and oil filter are very easy to access. The air filter is also very very easy to access. Unless you are changing the spark plug there's really no reason to remove the bed.
on back of engine behind back right tire (oil filter), beside passenger seat access would be by your left hip if you were riding passenger, behind a little rubber cover, easy to get to (oil fill),Where exactly is oil filter & oil fill, & how do you get to them? Thanks much!
