I built me a set of cooling fans not very expensive to build and welll worth the effort
Used steel frame 1/2” square tubing 3/16” lexan
16” radiator fans 3,000cfm 12v 120w digital potentiometers for adjustable speed PWM frequency=25khz if you build with these u need to use 20khz or higher because low ones will make the motor have a whiny noise
Used nylon washers and spaced the seat about a half inch feels much better than stock
sealed up the windshield , roof , back glass and tailgate used automotive weather stripping
make some jerky holsters out of some pvc sheet i had
