Same thing on my machine. It started midway between the two marks, dropped down after the first few hrs and it has stayed at the low mark since after my first ride. I haven't added any because I wanted to see if it dropped more, but it hasn't. So I will add more before I go out again.
its normal.. mine was down,then back up.. u know if u had a leak..sweet smell.. i found my grizzly the same way.. for some strange reason it used more coolant in the winter months..figured it be the other way round
I manufacture a coolant that does not ebb and flow out of the radiator and into the over flow bottle. It operates at 1-2 psi and lasts the life of the vehicle. Maximum temperature is 374°F.
Same on mine, halfway when i first got it and it went to low. Filled it back up and 800 miles later no change from full. System just needs to be burped.
