I installed Big Horn Originals today on factory aluminum wheels (Yes Ugly). Took some measurements for others. Used digital bathroom scale, so take with grain of salt, but still representative. Hope helps
Original 2.0 on Factory Aluminum Wheels
Front 31LB Mounted Tire Only 19LB Width Mounted 7.5"
Rear 37LB Mounted Tire Only 25 LB Width Mounted 9.5"
Measured Diameter off vehicle mounted 24.75" to 25"
Replacement Original Big Horn
Front 26x9x12 37.5LB Mounted Tire Only 25LB Width Mounted 9"
Rear 26x12x 12 45lb Mounted Tire Only 33LB Width Mounted 12"
Measured Diameter off vehicle mounted 26.5" 26.75"
Gained almost 1" Ground Clearance
For Record all 4 new tires took about 4oz to balance (3.6 to 4.4 oz)
Have not driven yet so can not say if or how much power I lost with additional 28LB added rotating weight & bigger diameter
Sorry about the pictures but used cell phone rather than camera
