I just checked my upper springs and they are completely collapsed , almost like a solid spring, the rear upper springs are about 75 % collapsed, and that is after I turned the adjuster lock nuts off and rotated the spring 4 complete turns up, trying to get a smoother ride.
kenner
Let’s just be careful not to confuse the terms “collapsed” and “compressed”!
Collapsed springs are weak and have sagged! Compressed springs are simply under compression by the adjusting nut! All of these units come with the tender springs from factory under compression by Yamaha. They are not collapsed. At least “NOT YET” The fronts are under much more compression than the rears.
No doubt aftermarket tender springs will be a benefit. No doubt a true crossover ring allowing them to work independently will be an even bigger benefit.
The ride is acceptable to me but we all know it could be better, It’s all about money!
I’ll probably run mine for 2-3 years and then Shock Therapy or some entity will have a good system dialed in. By then the shocks could use some maintenance so it will be a good to time to spend some money on a top notch spring package and have the shocks serviced and re-valved for the best possible ride it’s capable of.
I’m certainly interested in what the Bandits do, but it would have to be a significant honest improvement in ride quality all while maintaining at least the same ride height with the tender spring not under so much compression, otherwise I’ll wait on Shock Therapy to to work up the optimum package rather than have the shocks nickel and dime me!
