Sorry this is the best pic I have of it, don't have the machine at the house right now to get any pics. I just drilled a hole in the flat piece of metal of that roll bar bracket. I believe I had to flip the light around in the bracket to get them at the right angle.wi rider. would like to see close ups of the lights on the machine. to see what u used for mounting brackets and where you put them. i have these on order.
KAWELL® 2-Pack 18W 1260 LM CREE Flood 60 Degree Led Work Light Bar LED Off Road LED Work Light Worklamp Flood Beam ATV SUV Jeep Mine Boat Lamp
I think they work really well mounted there. High enough and protected that you really can't break them off......without tryingcool thanks. do they work well mounted there? thats where i was thinking of mounting them. all my accessories should be in this week.
I got these https://www.amazon.com/gp/aw/d/B00LX28WAO/ref=ya_aw_od_pi?ie=UTF8&psc=1
and mounted them up on the roll cage. Did mine on a switch, rather than reverse so that if you're pulling someone or hooking straps up in the dark you can turn then on without being in reverse. View attachment 5673
I thought you were saying when you put the wolverine in reverse they automatically come on.Same way as a light bar. Just used ignition on wire from 12 plug, a 2 light harness with a relay and power wire to the battery.
