Thanks man. So tired of buying the wrong stuff.I use Rocker Switch Pro. https://rockerswitchpros.com/
I do the custom actuators for text and graphics, stayed with the horizontal style, but you have options. Pick you light color and style for the body.
Are all the rockers the same physical size?I like OTRATTW switches. Plenty of options and way better success than the cheap rockers on Amazon.
The Happy Hour switch is the AUX battery power switch that activates the relay block to power the stereo and other accessories/lights/volt meter. The relay block is in lieu of a fuse block: Amazon.com: GEP Universal Pre-Wired Waterproof ATM Mini 4 Fuse 3 Relay Panel 80 AMP 12V : Automotivewhats the happy hour switch?
