1 - 20 of 28 Posts
Took the RMAX 2 out for its first weekend trip. There was a lot of likes and some dislikes about the bike. But for this thread I just want to know if anyone has gone with bigger tires yet on the RMAX. Im down here in east Texas and there are alot of roots and ruts that require ground clearance. Like to see some pics if you have them . I have a wheel and tire combo in mind but I am going to tackle some smaller less expensive projects first
2021 RMAX4 1000
What size are you thinking? I've seen a few pics of people running larger tires on the FB groups. I put a slightly larger tire on mine but only to get to the same size as you RMAX2 guys. I don't think any of to OEM 30'S are true to size though. I definitely noticed an increase in my ground clearance on mine. I have had many people think I was running 32's.
92713
Reactions: Wolverinegramps
I do really appreciate a nice set of tires (y)
2021 RMAX4 XTR
I uh want to well hmm lost my concentration there for a moment, back to bigger tires, I have the Rmax4, it has 29's I want to go up a size to 30's but will need to purchase spacers, new wheels and such so I may for now just stick to 29's as Tusk Terrabites are offered in the size I would need and personally I like them as I had them on the X2.
2021 RMAX4 1000
32's shouldn't be an issue. Especially since most of them are only around 31" tall. Not sure about 33's. I've seen a couple pics with them but still not sure. IMO they look way too big for the machine in the pics I've seen. Maybe if a lift kit was installed.
I'm running 28's on my X2 and I can go anywhere my buddies go that are running 32's and frame out.
Just pick a slightly different line. A inch or two one way or the other makes the difference.
Discussion Starter #9
Super atv says with the 2inch lift you can run up to 33 . I'm sure other lift kit will be available shortly. Just to have more option.
Pretty good chance in right at a month from now I’ll be testing a set of brand new 32s that I may buy from my nephew. Before purchasing I’ll run them for a couple days in Moab where they’ll go through full extension and full lock. I’ll be able to give a good report after that on any rubbing issues and performance with the larger tires.
Reactions: Rod12056
What brand tire are you trying? I like the looks of the XTR370 for an all around tire:
Those look very similar to a carnivore. They should do pretty well.
The tires he’s selling me are BF Goodrich KM3s, mounted on those same System 3 St3 bronze wheels in the link you sent. It’s a 1450.00 package for 800 bucks so I can’t turn it down. From everything I’ve researched they are comparable to slightly better than Terrabites on slick rock but much tougher in the sidewall. I was going to get Terrabites so this good since they are also quite a bit more money. Then I can swap summer and winter tires with no hassle. Reviews say they wear really well and are bullet proof on toughness in hard rocky terrain. I don’t see them so much as an all around tire like those system 3s or carnivores but they are pretty proven on the slick rock too so I’d use them as a summer tire in our hard rocky desert and high country conditions and save the carnivores for the spring mud and winter snow till there wore out.
I've seen a video with a guy running those BFG's on muddy rocks and they did way better than I expected.
I've seen a video with a guy running those on muddy rocks and they did way better than I expected.
Yeah I was pretty surprised. They just look pretty ordinary. One things for sure is a lot of desert races and KOHs have been won wearing them.
I'm about to pull the trigger on 32's but I am waiting for my wheels to show up to the US
Once those wheels are here i'm probably buying 32" Maxxis Rampages (specifically 32x10x15). The Rampages are a nice cross between Roxxzillas and Carnivores.
when are you headed to moab?
Ugh. I'm going in mid May. Let me know how you do. I have a full trail list. I'll update that in a Moab thread.
1 - 20 of 28 Posts
