Well, so far so good. My wife and I took the RMAX on a 22 mile test run. The temperature is 25°F “Feels like 18°” tonight. Our drive included about 10 miles at 40 mph and the rest was 20 to 35 with some stop and go and idle time at stop signs and waiting for the Union Pacific train. Hopefully this all makes sense because I had to make quick notes on my phone at each stop and that chicken scratch is what I’m going off of, so if I get too boring, confusing, or long winded, just ignore me lol.
Once warmed up, the air from the vents maintained around 84-90° with the bilge blowers only, without the radiator fan, at idle, and averaged 60-65° temps around the cab away from the vents. Rad fan and blowers combined at idle was 125-132° at the vents and would bring the cab temp up to the high 70’s before the radiator fan kicked off again. At crawling speeds, we’d be able to comfortably ride without jackets, but at higher speeds, too much cold air creeps in from the doors. While moving, the air at the vents varied between 112-128° with blowers only dependent on engine temp and speed. It cycled up to around 140-144° when the radiator fan kicked on with the blowers. Speed increased the “blower only” heat at the vents but with diminishing returns in the cab due to cold air leaks. I checked the blower housing temps several times during our drive. With vent air reading around 140, the hottest blower housing read 82°, and the plastic never felt like it was getting overly warm, so I think the heat sinks and aluminum sleeve combined with the cold outside air are keeping the blower housing temps well into an acceptable range.
With just the bilge blowers, the vents seem to put out about the same heat and double the airflow of my old Honda Civic heater. I’ll need to come up with something to stop the damned cold air that’s coming through the door gaps and hitting our door-side legs because that’s the only downside at the moment. We were warm overall, wearing just jeans and light coats, but both of our door-side legs were freezing after that long stretch at 40 mph.
