Yesterday I was finally able to fully assemble my Wolverine with every single clutch part we sell and I added the Power Commander to it. By fully assemble I mean side panels and clutch cover on plus the bed.
Keep in mind this has the .5 mm shim in it too which should drop top speed slightly
I was driving down a paved wrong and I was going down a slight down grade but I hit 62 mph where before when I had the PCV on it just 60.
Flat ground there was only enough power to hit 58-59 but was able to hold it there easily, without the PCV it banged off the limiter at 57 mph.
I really don't think too many people are wanting to run a Wolverine that fast and I really don't think the money spent on the PCV for that one reason makes it a good value.
But with our fuel maps it does add some fuel down low where the Wolverine is running very lean and it will lower the exhaust temps so the bed and rear diff does not get as hot.
Todd
Todd
