4 Point Harness RMAX 1000
3281 Views 7 Replies 4 Participants Last post by  radparts
2
In case anyone was wondering you can put a 4 point harness in a RMAX
See less See more
  • Love
Reactions: 4
1 - 8 of 8 Posts
I still need to do this. One of the best upgrades that can be done but I'm slacking.
Reactions: 1
Here’s the pass through I used. Also you need to get the Yamaha fasteners that are used for the yxz to mount the bottom of the harnesses correctly.
Reactions: 2
You’ll need to make one cut right about the middle seam in the front of the seat then cut out the foam. Trace the back of the seat from the inside then drill a marker hole from the front out the back. Then take a cut off wheel and connect the dots. From there it’s trim to fit.
Reactions: 1
Above the middle seam*
Reactions: 1
We have 4 point harness kits available for the rmax uses yxz lower mounts from dragonfire includes pass throughs and ovverride plug Yamaha RMAX Harness kit 4 Point | Dragonfire Racing (rad.parts)
Reactions: 3
Where does the top belts mount?
wraps around the roll bar behind the seats
Reactions: 1
1 - 8 of 8 Posts
