1 - 14 of 14 Posts
Looks awesome!!!
If your going for a smooth ride. I would not recommend this lift. But I also need to loosen the suspension. The tires that I have don't help either. My top speed now is only 46 mph. The tires are really heavy. My friend put 28" big horn radials on his and his tops out at 56 mph. Go figure. I'll post more pics of the angles of the CV shafts.
46 on GPS or speedo. I hit around 57 with the Mega's with Sheave and PCV but that's 61 on the GPS. You really need a sheave with heavy 28's.
Discussion Starter · #12 ·
I think you should be able to but. I'm not sure you would like that unless you have some motor modifications. It really steals the power putting on bigger tires.
1 - 14 of 14 Posts
