This is a well optioned machine in stock form including:
999cc Parallel Twin Engine – Smooth & Reliable – 108HP
2WD, 4WD, Front Diff Lock + 3 Trail Modes (Sport, Trail, Crawl)
FOX QS3 Reservoir Shocks (with 3 setting adjusters) 14” Front Travel + 16” Rear Travel
4 Wheel Disc Brakes
LED Lights
Tilt Cargo Bed (600lb capacity) + 2000lb towing
Warn VR 4500 Winch
Integrated Yamaha Adventure Pro (in dash GPS Tablet)
[ Fully Enclosed Cab ]
Yamaha Glass Windshield w/ Wiper & Washer
Yamaha Soft Doors
Yamaha Glass Sliding Rear Window
Custom Rubber Floor Mats
[ Street Ready ]
Ryco Turn Signal + Horn + License Plate Kit
Side View Mirrors w/ LED Lights (wired in dash switch)
Sound Deadening (roof, floor, rear and interior panels)
[ Capability Enhancements ]
(5) Method 15x7 MR409 Bead Grip Wheels (dot legal)
(5) Milestar SXT 34x10R15 Tire (dot legal w/ replacement warranty)
Trail Amor Full Belly UHMW Skids
Custom Steel Bed Rack (Spare Tire Holder, Flag Mount, Shovel Mount)
Joes Shock Bump Stop Shim (for rear suspension tire fitment)
Front Rhino 2.0 HD CV Axles
Rear Rhino 2.0 HD CV Axles
Front High Clearance 1.5” Forward Offset A-Arms w/ HD Ball Joints
Rear High Clearance A-Arms
Bandit Tender Springs (front/rear)
PRP Suspension Limit Straps (front/rear)
Weller Racing HD Tie Rod Kit w/ boots
Warn Synthetic Rope w/ Hawse Fairlead + Rubber Stopper
Warn Wireless Controller Hub (phone app controller)
(2) RotoPax 2 Gallon Fuel w/ Bed Mounts
[ Performance Enhancements ]
Welller Racing DynoJet w/ Tunes Loaded
Weller Racing Air Injection Block Off Plate
CVT Shim (lower crawl ratio)
HealTech Speedometer Calibrator (correct speedo for 34” tires)
Weller Racing Clutch Kit (bottom end performance) sheave + spring
OVER $15,000 in Parts (plus $3,000 in Labor)!
Maintenance Performed:
  • Initial Break-In Service (oil change, differential service)
  • 1,000 miles Mobil1 4T 10w40 oil change + differential service + full clutch service + Spark Plugs + Air Filter Clean
  • 1,400 miles clutch upgrade WR Sheave + Spring + all seals + tinkseal + roller weights
  • 1,500 miles Mobil1 4T 10w40 oil change + differential service (gear butter)
Current Miles: 1,571
Video Walk Through:
Upgrade Options:
Upgrades.pdf
[ + Stock Take Off Parts = $500 ]
[ + New! Replacement & Service Parts = $500 ]
[ + Recovery Gear Upgrade = $200 ]
[ + Factory Wheels/Tires = $500 ]
[ + Overland Camping Ready Package = $500 ]
[ + (2) Sena Tufftalk Lite Headsets = $400 ]
Mix and Match. Add whatever additional parts you want!
$27,900 - Private Seller (NO TAX)
503-888-6967 or [email protected]
