1 - 16 of 16 Posts
When I am crawling downhill, particularly over rocks or uneven terrain, there is a clanking sound coming from directly beneath the center of the machine, and not because I am hitting rocks on the underside. I assume it is the interplay between the drive shaft and the engine brake trying to hold the machine back, but it is quite annoying and sounds like it is hitting harder than it should be. My 10-year-old even noticed it and said something about it.
Doesn't happen on flat or uphill surfaces.
Any ideas? Or just the nature of the beast?
Same sh!t here, downhill on rocky roads I swear there's something wrong.
Doesn't happen much elsewhere but it does sometimes when decelerating on semi-flat roads also.
Nature of the beast: Engine braking, one-way sprag, driveline lash.
What Massive said. All of my Yamaha ATV's over the years and my Wolverine make the same sounds on descents. The one way bearing (engine braking) and the driveline are engaging/disengaging causing the noise, it's normal as far as I'm concerned.
Thanks for the feedback folks. Much appreciated. Glad to know it’s not a repair bill!
Now you can wait for the day when the one way bearing fails. I've worn one out on my old Grizzly plow rig, it was weird as sometimes I would have engine braking and other times it would just free roll, that is when you know how nice it is to have. I rarely use my brake pedal, except when needed.
Speaking of one way bearing.................last trip out I noticed mine was working intermittently.
This is my first machine with CVT but I'm guessing that mines taking a dump???
And I cant find one online at the parts houses I frequent.
Out of curiosity, how many miles on yours at this point?
5100+
Did get the new tie rod ends on, the old ones had a fair amount of slop.
Reactions: Budro2
5100+
I’m at almost 4900 , that’s why I was curious. Wondering if that’s i my near future!
About 2000
I'm about to hit 7000 miles, all on synthetic, with no issues, but the X2/X4's one way is much beefier.
Bring that thing to Moab, we'll give that bearing a work out on the rock rollercoaster!
Been there, done that! LOL
Great video, you can actually see how steep it really is!
Reactions: MassiveOverkill
1 - 16 of 16 Posts
