Ran into my first issue. Been riding around low desert Phoenix for awhile and ever had issues with overheating or remotely close to it. Loaded up the Wolverine last week to up near Grand Canyon (cooler temps) and arrived to my destination. Unloaded the Wolverine and I noticed the Coolant Temp Light came on the minute I started it up. I also noticed "Lo Cool" or something similar on the LCD screen. Mind you it was about 80 degree outside, nothing crazy. Coolant level was good in reservoir, exactly in the middle of full and minimum. Engine was still cool so I checked the radiator, coolant was full to the top and cap worked. I drove it the first trail head and watched the coolant temp rise FASTER than normal and I never heard the fan kick on. It was a short run and temps got up much higher than normal around 200 and it was an easy ride. You can smell excessive heating of coolant. After the hike I drove it back to the camp site with a stop in the middle this time to ensure it didn't get as hot as it did. The fan moved freely and easily, fan fuse was good, coolant level was normal and radiator was clean as a whistle since I washed it before the trip.
My schedule is limited for next few weeks and I had the YES warranty, so I opted to just drop it off at dealer. Couple things I began to ponder. 1. Why the "lo Cool" indication when levels were good and outside tempt was 80 and it popped up right at start up. 2. The cooling fan is defective like others have posted, but the bearings allowed it to move freely(still could be bad?). 3. The fan relay switch may have went bad. 4. The thermostat could be stuck open 5. Water pump? Wouldn't explain the the fan issue though.
Anyways, I plan to do a follow up post for those that are curious and assist with searched in the future for trouble shooting.
Not going to lie, I am second guessing myself now and I used to remember what temp the fan kicked on and I swore it wasn't as hot as 200. Plus the engine smelled as if the coolant or engine reached excessive heat and I never got that hot..even when it's 110 in the desert.
